[geos-devel] Problems with BufferOp when using BufferParameters
Mateusz Łoskot mateusz at loskot.net
Fri Oct 28 19:36:34 EDT 2011
On 28 October 2011 10:39, Markus Meyer <meyer at mesw.de> wrote:
> Mateusz,
> thanks for creating the test.
> Here are information about the used coordinates and the used offset (dumped
> from the code):
> Coordinate #0 = 0.0, 0.0
> Coordinate #1 = 100.0, 0.0
> Coordinate #2 = 100.0, 100.0
> Coordinate #3 = 0.0, 100.0
> Coordinate #4 = 0.0, 0.0
> fOffset = 5.00
Markus,
I rather meant to use your geometry in the test, in case 1) it is
possible to receive it
2) it is not a giant, so it will fit in WKT form into BufferOpTest.cpp file.
See comment and placeholder here:
http://trac.osgeo.org/geos/browser/trunk/tests/unit/operation/buffer/BufferOpTest.cpp?rev=3509#L282
> Is there any chance that this problem is being fixed soon?
Perhaps Sandro is working on it.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
