[geos-devel] Re: [GEOS] #518: GEOS 3.3.2 crashes on MinGW64
GEOS geos-trac at osgeo.org
Sun Apr 1 05:57:31 EDT 2012
 Reporter:  esseffe     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.3
Component:  Default     |     Version:  3.3.2
 Severity:  Unassigned  |    Keywords:
Comment(by robe):
 okay I upgraded my mingw64 to gcc 4.6.3 and now I'm experiencing crashing
 in xmltester.exe to.  I'm pretty sure it was working fine on my 4.4.7 (or
 something like that).  I'm going to roll back to that one or my 4.5 next
 to see if I get the same issue.
 For me it fails here:
 this is running branch 3.3 r3574
 terminate called after throwing an instance of
 'geos::util::TopologyException'
   what():  TopologyException: found non-noded intersection between
 LINESTRING (-
 105571 939969, -102895 939993) and LINESTRING (9485.36 770763, -102895
 939993) a
 t -102894.5562421389 939992.66927296668
Ticket URL: <http://trac.osgeo.org/geos/ticket/518#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
