[geos-devel] [GEOS] #527: Union and UnaryUnion both fail at correctly node input lines
GEOS geos-trac at osgeo.org
Mon Apr 2 05:02:03 EDT 2012
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.4
Component:  Default     |     Version:  3.3.3
 Severity:  Unassigned  |    Keywords:
 GEOSUnaryUnion fails to correctly node this line:
 MULTILINESTRING((1725063 4819121,1725104 4819067,1725060
 4819087,1725064.14183882 4819094.70208557,1725064.13656044
 4819094.70235069,1725064.14210359 4819094.70227252,1725064.14210362
 4819094.70227252,1725064.13656043 4819094.70235069,1725055 4819094,1725055
 4819094,1725055 4819094,1725063 4819121))
 I'm assuming ST_IsSimple is a good sign of correct noding:
 =# select ST_IsSimple( ST_UnaryUnion( 'MULTILINESTRING((1725063
 4819121,1725104 4819067,1725060 4819087,1725064.14183882
 4819094.70208557,1725064.13656044 4819094.70235069,1725064.14210359
 4819094.70227252,1725064.14210362 4819094.70227252,1725064.13656043
 4819094.70235069,1725055 4819094,1725055 4819094,1725055 4819094,1725063
 4819121))' ) );
  st_issimple
  f
 (1 row)
Ticket URL: <http://trac.osgeo.org/geos/ticket/527>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
