[geos-devel] Re: [GEOS] #527: Union and UnaryUnion both fail at correctly node input lines
GEOS geos-trac at osgeo.org
Mon Apr 2 09:29:59 EDT 2012
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.4
Component:  Default     |     Version:  3.3.3
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Further analysis: the first attempt at running the union overlay op fails
 the internal noding validator step:
 EdgeNodingValidator found noding invalid: TopologyException: found non-
 noded intersection between LINESTRING (1.72506e+06 4.81909e+06,
 1.72506e+06 4.81909e+06) and LINESTRING (1.72506e+06 4.81909e+06,
 1.72506e+06 4.81909e+06) at 1725064.1365604457 4819094.70235069
 So SnapIfNeededOverlayOp switches on snapping, which seems to pass the
 check:
 EdgeNodingValidator accepted the noding
 Now it'd be interesting to see _why_ the internal edge noding validator
 passes while our own checking fails it !
Ticket URL: <http://trac.osgeo.org/geos/ticket/527#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
