[geos-devel] [GEOS] #605: Crash from GEOSBuffer: RightmostEdgeFinder.cpp: Assertion `checked>0` failed
GEOS geos-trac at osgeo.org
Tue Dec 4 06:30:55 PST 2012
failed
 Reporter:  strk      |       Owner:  geos-devel@…
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  3.3.7
Component:  Default   |     Version:  3.3.6
 Severity:  Critical  |    Keywords:
Comment(by strk):
 I've attached an XML test for comparing JTS and GEOS against. The input is
 a further reduction. The expected output is actually unknown but JTS is
 clearly giving a bogus answer:
 http://strk.keybit.net/tmp/grossbuffer.png
Ticket URL: <http://trac.osgeo.org/geos/ticket/605#comment:11>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
