[geos-devel] [GEOS] #509: GEOS crashes on check in MingW GCC 4.6.2
GEOS geos-trac at osgeo.org
Wed Feb 8 20:06:57 EST 2012
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.3
Component:  Default     |     Version:  3.3.2
 Severity:  Unassigned  |    Keywords:
 strk,
 Attached are the errors I was taking about.
 This is using the latest MingW which comes packaged 4.6.2 GCC.  This isn't
 the mingw-64 chanin just regular old mingw.
 Bborie has similar issues.
 Here is tail end
 ./tests/robustness.xml: case4: test1: areatest(): failed.
         Description: http://postgis.refractions.net/pipermail/postgis-
 users/2006-March/011332.html (2)
         Geometry A: POLYGON
 ((79911351935872790944815880334705273512056967399003741615532817923782037519475428109099665876573130584942156313690227581281468388076790258227363916421792397683444114397173745128036903519643930106040505272739336078817222481449238163738797272244474490799100222534487900160.0000000000000000
 79911351935872204420063629967499807015362005738311451634314571868818234558585524778508836249095947193520392225301098787998719582962523134579655611559037572569310783154583117024371076105380075681950670183253998580397853895306569856681059406258762048251140281940920238080.0000000000000000,
 79911351935872248409420048745040217002614127862863373382905940322940519780652267528303148471156735947877024531930283447494925743346093168853233734423744184452870782997777414132146013161449864763757407814965398892779306539267269979710389746207690481442237277485437812736.0000000000000000,
 79911351935872805607934686593885410174474341440521048865063274075156132593497675692364436617260060169727700415899955801113537108204646936318556624043361268311297447678238510830628549205000526466642751149976469516277706696102804871415240718894117301862799221049327091712.0000000000000000
 79911351935872263072538855004220353665031501904380680632436396474314614854674515111567919211843665532662568634140011667326994463473949846944426442045313055080724116278842179834737658846806461124359653692202532330239790753920836687386833192857333292505936276000277004288.0000000000000000,
 79911351935872277735657661263400490327448875945897987881966852625688709928696762694832689952530595117448112736349739887159063183601806525035619149666881925708577449559906945537329304532163057484961899569439665767700274968574403395063276639506976103569635274515116195840.0000000000000000,
 79911351935872233746301242485860080340196753821346066133375484171566424706630019945038377730469806363091480429720555227662857023218236490762041026802175313825017449716712648429554367476093268403155161937728265455318822324613703272033946299558047670378538278970598621184.0000000000000000,
 79911351935872321725014080040940900314700998070449909630558221079810995150763505444627002174591383871804745042978924546655269343985376559309197272531588537592137449403101242645104241588232846566768637201151066080081727612535103518092606979455904536760732270059633770496.0000000000000000,
 79911351935872175093826017449139533690527257655276837135253659566070044410541029611979294767722088023949304020881642348334582142706809778397270196315899831313604116592453585619187784734666882960746178428779731705476885465999436441328172512959476426123742284911241854976.0000000000000000,
 79911351935872160430707211189959397028109883613759529885723203414695949336518782028714524027035158439163759918671914128502513422578953100306077488694330960685750783311388819916596139049310286600143932551542598268016401251345869733651729066309833615060043286396402663424.0000000000000000,
 79911351935872189756944823708319670352944631696794144384784115717444139484563277195244065508409017608734848123091370568166650862834666456488462903937468701941457449873518351321779430420023479321348424306016865142937369680653003149004615959609119237187441283426081046528.0000000000000000,
 79911351935872776281697074075525136849639593357486434366002361772407942445453180525834895135886201000156612211480499361449399667948933580136171208800223527055590781116108979425445257834287333745438259395502202641356738266795671456062353825594831679735401224019648708608.0000000000000000
 79911351935872131104469598671599123703275135530724915386662291111947759188474286862184982545661299269592671714252457688838375982323239744123692073451193219430044116749259288511412847678597093878939440797068331393095432822038736318298842173010547992932645289366724280320.0000000000000000,
 79911351935872219083182436226679943677779379779828758883845028020192329632607772361773606989782876778305936327510827007830788303090379812670848319180606443197164116435647882726962721790736672042552916060491132017858338109960136564357502852908404859314839280455759429632.0000000000000000,
 79911351935872204420063629967499807015362005738311451634314571868818234558585524778508836249095947193520392225301098787998719582962523134579655611559037572569310783154583117024371076105380075681950670183253998580397853895306569856681059406258762048251140281940920238080.0000000000000000))
         Geometry B: POLYGON
 ((79911288958257134014671124892712743013627656751873257337071334876132260343049438785235460438699007416313412787511834915468090617739201263814999210971351697695949236051963992979569044479767643002167415708244162271858330575492354949167277861892594374708408316693764374528.0000000000000000
 79911351935872233746301242485860080340196753821346066133375484171566424706630019945038377730469806363091480429720555227662857023218236490762041026802175313825017449716712648429554367476093268403155161937728265455318822324613703272033946299558047670378538278970598621184.0000000000000000))
         Expected result: 1
         Obtained result: TopologyException: found non-noded intersection
 between LINESTRING (7.99114e+268 7.99114e+268, 7.99114e+268 7.99114e+268)
 and LINESTRING (7.99114e+268 7.99114e+268, 7.99114e+268 7.99114e+268) at
 7.9911351935872791e+268 7.9911351935872219e+268
 FAIL: testrunner
 1 of 1 test failed
 make[3]: Leaving directory `/c/projects/geos/branches/3.3/tests/xmltester'
 make[2]: Leaving directory `/c/projects/geos/branches/3.3/tests/xmltester'
 make[1]: Leaving directory `/c/projects/geos/branches/3.3/tests'
         Expected result: 1
 betwee
  LINESTRING (7.99114e+268 7.99114e+268, 7.99114e+268 7.99114e+268) and
 LINESTRI
 7.9911351935872791e
 Assertion failed: eiNew->coord.equals2D(intPt), file SegmentNodeList.cpp,
 line 83
 Attached is the full log
Ticket URL: <http://trac.osgeo.org/geos/ticket/509>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
