[geos-devel] JTS - Change to semantics of overlay operations with EMPTY outputs
Sandro Santilli strk at keybit.net
Tue Feb 28 03:26:48 EST 2012
On Mon, Feb 27, 2012 at 09:54:56PM -0800, Martin Davis wrote:
> * For symmetric difference, the output will have the type of the
> lowest-dimension input
>     E.g.
>     symDifference(POLYGON EMPTY, LINESTRING EMPTY) = LINESTRING EMPTY
>     symDifference(LINESTRING EMPTY, POLYGON EMPTY) = LINESTRING EMPTY
>     (This is pretty arbitrary, but no other criteria comes to mind)
I think it'd make more sense to use the highest, because it would be
  ST_Union( ST_Difference(A, B), ST_Difference(B, A) )
Which for your previous definitions means:
> * For difference, the output will have the type of the left-hand input
>     E.g.
>     difference(POLYGON EMPTY, LINESTRING EMPTY) = POLYGON EMPTY
>     difference(LINESTRING EMPTY, POLYGON EMPTY) = LINESTRING EMPTY
  ST_Union( dims(A), dims(B) )
Which in turn gives:
> * For union, the output will have the type of the highest-dimension input
>      E.g.
>     union(POLYGON EMPTY, LINESTRING EMPTY) = POLYGON EMPTY
  maxDim(A, B)
So symDifference(A, B) should have type of highest dimension input.
Does it make sense ?
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
