[geos-devel] Re: [GEOS] #515: mingw64 make check returns #IND
GEOS geos-trac at osgeo.org
Mon Mar 5 11:26:16 EST 2012
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  trivial     |   Milestone:  3.3.3
Component:  Default     |     Version:  3.3.2
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Did mingw32 give you the same failure ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/515#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
