[geos-devel] Modifying vertices without copying ?
Oyvind Idland oyvind.idland at gmail.com
Thu Mar 15 06:38:14 EDT 2012
I do use the C++ API, and have been taking a look at
geos::geom::util::GeometryTransformer.
geos::geom::util::GeometryTransformer is based on copying aswell, or, at
least I can't see
an way to change that behaviour ?
-- Oyvind
On Thu, Mar 15, 2012 at 11:02 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Thu, Mar 15, 2012 at 10:45:31AM +0100, Oyvind Idland wrote:
> > is it possible in some way to modify vertices on geometries, without
> making
> > copies ?
> It should be possible with the C++ api.
> Check out coordinate transformation classes.
> Probably not very well tested.
> --strk;
>  ,------o-.
>  |   __/  |    Delivering high quality PostGIS 2.0 !
>  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
>  `-o------'
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20120315/f1154cb2/attachment.html
