[geos-devel] Re: [GEOS] #522: Exception on overlay between valid linestrings [JTS fails too] (was: Exception on overlay between valid linestrings)
GEOS geos-trac at osgeo.org
Fri Mar 30 04:49:41 EDT 2012
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.3
Component:  Default     |     Version:  3.3.2
 Severity:  Unassigned  |    Keywords:  jtsfail
Changes (by strk):
  * keywords:  => jtsfail
Comment:
 JTS trunk revision 537 also fails:
 Test Threw Exception (A difference B)
 com.vividsolutions.jts.geom.TopologyException: found non-noded
 intersection between LINESTRING ( -1120500.0000001257 851294.299192949,
 -1120500.0000001257 851343.3885007716 ) and LINESTRING (
 -1120500.0000001257 851343.3885007716, -1120500.0000001257
 851342.2386007707 ) [ (-1120500.0000001257, 851343.3885007716, NaN) ]
Ticket URL: <http://trac.osgeo.org/geos/ticket/522#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
