[geos-devel] Re: [GEOS] #524: IntersectionMatrix of a line with itself has NO boundary intersection [JTS fails too]
GEOS geos-trac at osgeo.org
Fri Mar 30 10:52:27 EDT 2012
fails too]
 Reporter:  strk        |        Owner:  geos-devel@…
     Type:  defect      |       Status:  closed
 Priority:  major       |    Milestone:  3.3.3
Component:  Default     |      Version:  3.3.2
 Severity:  Unassigned  |   Resolution:  invalid
 Keywords:  jtsfail     |
Comment(by strk):
 For the record: passing boundary-node-rule 2 to GEOSRelate gives the
Ticket URL: <http://trac.osgeo.org/geos/ticket/524#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
