[geos-devel] Re: [GEOS] #513: Fix PHP 5.4 compatibility
GEOS geos-trac at osgeo.org
Wed May 9 09:30:08 PDT 2012
 Reporter:  voxik       |        Owner:  geos-devel@…
     Type:  defect      |       Status:  closed
 Priority:  major       |    Milestone:  3.3.4
Component:  Default     |      Version:  3.3.3
 Severity:  Unassigned  |   Resolution:  fixed
 Keywords:              |
Changes (by strk):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Please try r3624 (in 3.3 branch) or r3625 (in trunk).
 I've slightly modified the patch to have less #ifdefs -- didn't handle to
 simplify the object_properties_init vs. zend_hash_copy using a macro, if
 you can I'm ready to update (and test on PHP 5.3)
Ticket URL: <http://trac.osgeo.org/geos/ticket/513#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
