[geos-devel] [GEOS] #585: mingw64 trunk make check fail on badthreadtest
GEOS geos-trac at osgeo.org
Tue Sep 11 21:50:33 PDT 2012
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  minor       |   Milestone:  3.4.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by robe):
 This is a bit more complicated than I thought.  My windows 7 64-bit which
 is running the same version and gcc mingw64 as the windows bot.  The
 windows bot is windows 2003 64-bit.
 These errors are not showing up at all on my windows 7, however I'm
 getting a lot of xmltester failures which I think is a new issue. I'll
 post as separate ticket.
Ticket URL: <http://trac.osgeo.org/geos/ticket/585#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
