[geos-devel] [GEOS] #594: geos turns 'POLYGON EMPTY' into 'POLYGON(EMPTY)'
GEOS geos-trac at osgeo.org
Tue Sep 25 21:05:56 PDT 2012
 Reporter:  cdestigter  |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.6
Component:  Default     |     Version:  3.3.3
 Severity:  Unassigned  |    Keywords:
Comment(by cdestigter):
 Even worse, I can't even use hex to create the geometry, which means I
 can't work around the bug:
     >>> geos.GEOSGeometry('010300000000000000').hex
     '01030000000100000000000000'
Ticket URL: <http://trac.osgeo.org/geos/ticket/594#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
