[geos-devel] [postgis-devel] GEOS 3.4.0 is out
Sandro Santilli strk at keybit.net
Sun Aug 11 02:37:50 PDT 2013
Sorry for arriving late here, but there's a problem with generation
of platform.h.  HAVE_ISNAN, HAVE_ISFINITE, HAVE_LONG_INT_64 are all
undefined after I run ./configure (but they are defined in config.h).
I spotted the problem being carriage returns in the platform.h.in file
which probably makes the configure script unable to match the macro names.
What I don't understand is why there are no CR in my local git-svn
snapshot, maybe a missing SVN property on that file, but I've never
learnt how to manage those props with SVN and I'd rather not start
now.
In any case we need to fix this ASAP. Maybe we can call it a packaging
issue and just re-generate the tar.bz2, without changing version, what
do you think ?
--strk;
On Sun, Aug 11, 2013 at 01:15:45AM -0400, Paragon Corporation wrote:
> The GEOS development team is proud to release GEOS 3.4.0 which you can
> download from: http://download.osgeo.org/geos/geos-3.4.0.tar.bz2
> Svn: https://svn.osgeo.org/geos/tags/3.4.0
> - New things:
>   - Delaunay Triangulation API (#487, #565, #570, #567)
>   - Interruptibility API (C and C++)
>   - CAPI: GEOSNode (#496) - PHP: Geometry->node
>   - GeometryPrecisionReducer class (#496, #526)
>   - BufferInputLineSimplifier header exposed (#548)
>   - New Centroid class supporting mixed geometry components (#612)
>   - io::Writer::reserve() method
>   - CAPI: GEOSNearestPoints
>   - Add --cclibs, --static-clibs and --static-cclibs to geos-config (#497)
>   - Early bail out of overlay exception if input is invalid
> - C++ API changes:
>   - New noding::GeometryNoder class
>   - Added BufferOp::setSingleSided
>   - Signature of most functions taking a Label changed to take it
>     by reference rather than pointer.
>   - Signature of most functions taking an IntersectionMatrix changed
>     to take it by reference rather than pointer.
>   - GraphComponent::label is now a Label value (from a pointer)
>   - NodedSegmentString takes ownership of CoordinateSenuence now
>   - io::Writer's toString() returns by const ref, write() takes a const ref
>   - Unify prototypes of WKTReader and WKBReader constructor (#310)
>   - GeometryCollection::computeEnvelopInternal and
>     GeometryCollection::compareToSameClass are marked virtual (#478)
> - Bug fixes / improvements
>   - A point interpolated from a line does not always intersect
>     the same line (#323)
>   - Port ConvexHull robustness fix from JTS-1.13 (#457)
>   - Improve Overlay robustness by reducing input precision on topology
>     exception and by refusing to accept unnoded output (#459)
>   - Improve Buffer robustness by reducing input precision on topology
>     exception (#605)
>   - Mismatch segment sides in OffsetCurveBuilder (#633 )
>   - Fixed Linear Referencing API to handle MultiLineStrings consistently
>     by always using the lowest possible index value, and by trimming
>     zero-length components from results (#323)
>   - Fixed CMake configuration to set correct SOVERSION (current - age)
>   - Fix EMPTY return from single-point lines and zero-length polygons (#612)
>   - CMakeLists.txt, tools/geos_svn_revision_cmake.h.in: Add
> 	  geos_svn_revision.h generator to CMake config (#643)
> 	- Makefile.vc 'clean' step leaks obj files (#607)
> Please test and report any issues.
> Thanks,
> Regina and rest of GEOS Development Team
