[geos-devel] [GEOS] #648: Change svn/git line breaks to Unix
GEOS geos-trac at osgeo.org
Sun Aug 11 12:56:14 PDT 2013
 Reporter:  robe         |       Owner:  geos-devel@…
     Type:  enhancement  |      Status:  new
 Priority:  minor        |   Milestone:  3.5.0
Component:  Default      |     Version:  3.4.0
 Severity:  Unassigned   |    Keywords:
Comment(by mwtoews):
 I think it would be overkill to convert all files to have LF eol-style.
 There is only a few files that require LF only, such as shell scripts and
 other files processed by Perl (I think). The majority of files are OK with
 eol-style=native.
 I can come up with a list of SVN property changes, but not in the next bit
 of time.
 The bzip2 packaging OS must either be a POSIX system, or one that SVN can
 configured as LF system (Tortoise SVN can do this?). Git on Windows can be
 configured to either convert or keep EOLs, but it doesn't use properties
 in the same way SVN does.
Ticket URL: <http://trac.osgeo.org/geos/ticket/648#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
