[geos-devel] [GEOS] #649: ST_Snap crashes on some inputs
GEOS geos-trac at osgeo.org
Fri Aug 16 05:22:06 PDT 2013
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.1
Component:  Default     |     Version:  3.4.0
 Severity:  Unassigned  |    Keywords:
 This was logged as an issue in PostGIS at:
 http://trac.osgeo.org/postgis/ticket/2426
 Doesn't seem to be an issue in 3.3
 SELECT ST_Snap('POLYGON Z ((-71.1319 42.2512 0,-71.1318 42.2511
 20,-71.1317 42.2511 -20,-71.1317 42.251 5,-71.1317 42.2509 4,-71.132
 42.2511 6,-71.1319 42.2512 30))'::geometry, 'GEOMETRYCOLLECTION Z
 (MULTIPOLYGON Z (((-71.0821 42.3036 2,-71.0822 42.3036 2,-71.082 42.3038
 2,-71.0819 42.3037 2,-71.0821 42.3036 2))),POLYGON Z ((-71.1261 42.2703
 1,-71.1257 42.2703 1,-71.1257 42.2701 1,-71.126 42.2701 1,-71.1261 42.2702
 1,-71.1261 42.2703 1)))'::geometry, 0.5)
 Just in case that doesn't crash for you, the original I was trying it from
 was a statement generated by the PostGIS garden monkey script.
 {{{SELECT ST_Snap(foo1.the_geom, foo2.the_geom, 0.5) As result,
 ST_AsText(foo1.the_geom) As ref1_geom, ST_AsText(foo2.the_geom) As
 ref2_geom
         FROM ((SELECT geom  As the_geom
 FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1319 42.2503
 1,-71.132 42.2502 3,-71.1323 42.2504 -2,-71.1322 42.2505 1,-71.1319
 42.2503 0))') ),
         ( ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1319 42.2512 0,-71.1318
 42.2511 20,-71.1317 42.2511 -20,-71.1317 42.251 5,-71.1317 42.2509
 4,-71.132 42.2511 6,-71.1319 42.2512 30))') )
                 )       As g(geom))) As foo1 CROSS JOIN ((SELECT
 ST_Collect(geom)  As the_geom
                 FROM (VALUES (
 ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.0822
 42.3036 2,-71.082 42.3038 2,-71.0819 42.3037 2,-71.0821 42.3036 2)))') ),
         ( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.1261 42.2703 1,-71.1257
 42.2703 1,-71.1257 42.2701 1,-71.126 42.2701 1,-71.1261 42.2702 1,-71.1261
 42.2703 1))') ) ) As g(geom) CROSS JOIN generate_series(1,3) As i GROUP BY
 i )) As foo2 LIMIT 2;
Ticket URL: <http://trac.osgeo.org/geos/ticket/649>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
