[geos-devel] [GEOS] #652: 32-bit regression failures
GEOS geos-trac at osgeo.org
Tue Aug 20 07:21:39 PDT 2013
 Reporter:  mwtoews     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.5.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:  32-bit
Changes (by robe):
  * milestone:  => 3.5.0
Comment:
 I get 3 regression failures (on winnie Windows 2003 64-bit R2) my 32-bit
 mingw64w32 gcc 4.5.4.  I get a lot more for 64-bit on Winnie (but I think
 something else is going on with that).  On an old windows xp I tested (I
 think 3.5 doesn't compile at all and that's a recent development with
 latest commits I think)
 I've attached my make check log.  Haven't check to see if its the same
 failures as Greg
Ticket URL: <http://trac.osgeo.org/geos/ticket/652#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
