[geos-devel] [GEOS] #656: GeosisValidDetail mingw64-w32 gcc 4.5.4 POINT (1.#QNAN -5)
GEOS geos-trac at osgeo.org
Wed Aug 21 08:30:55 PDT 2013
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.9
Component:  Default     |     Version:  3.4.0
 Severity:  Unassigned  |    Keywords:
 group: capi::GEOSisValidDetail, test: test<3>
      problem: assertion failed
      failed assertion: "Expected 'POINT (NAN -5)' or 'POINT (-1#IND -5)',
 Obtained 'POINT (1.#QNAN -5)"
 I think this is a harmless error, but its preventing tests from
 continuing.  This I'm seen in winnie's building of 3.3.9
 (I need to set test for 3.4, 3.5)
 I suspect it will be an error for 3.4. and 3.5 too.
Ticket URL: <http://trac.osgeo.org/geos/ticket/656>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
