[geos-devel] What's still pending for 3.4.2 ?
Paragon Corporation lr at pcorp.us
Thu Aug 22 04:56:20 PDT 2013
Also have the 32-bit regression failures people should confirm is fixed for
them.
http://trac.osgeo.org/geos/ticket/652
I'm still having issue on windows regression failures with 3 or 4 failures,
but since I think those have always existed I'm okay to release with them.
Devrim,
I know you had trouble compiling in Fedora because of some ruby thing, not
sure if that is covered/ticketed in our changes or not.  I don't see it.
Before we do another run, can you make sure you can compile with latest
nightly tar ball? http://geos.osgeo.org/snapshots/
Thanks,
Regina
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
Sent: Thursday, August 22, 2013 6:22 AM
To: geos-devel at lists.osgeo.org
Subject: [geos-devel] What's still pending for 3.4.2 ?
Changes since 3.4.1 so far:
  - Use a double for PrecisionModel scale, avoiding overflows (#652)
  - isnan workaround OS detection missing NetBSD, DragonFly, Sun nuance
(#650)
  - Do not distribute platform.h and version.h, but install both (#601)
Plus the CAPI library version was properly set to 1.8.2 (3.4.0 and 3.4.1)
both went out versioned as 1.8.0. A confirmation of this from the packagers
would be helpful: http://trac.osgeo.org/geos/ticket/653
In addition to the above, critical issues, there's the annoyance of format
change for the ChangeLog file: http://trac.osgeo.org/geos/ticket/654
Is that all we need closed for a good 3.4.2 release or did anyone notice
anything else to fix ? It would be nice to get a 3.4.2 out ASAP (tomorrow?),
given none of the existing 3.4.x releases are working...
--strk;
geos-devel mailing list
http://lists.osgeo.org/mailman/listinfo/geos-devel
