[geos-devel] GSoC '13 Weekly Report 3- Adding Voronoi Diagram to GEOS
vishal tiwari hi.vishal123 at gmail.com
Mon Jul 8 21:51:55 PDT 2013
Hey,
I have forked the original repository [1], and will now be working on it. :)
[1] https://github.com/libgeos/libgeos/
Thanks,
On 8 July 2013 21:54, Sandro Santilli <strk at keybit.net> wrote:
> Vishal, I've noticed you're doing your work into an isolated
> repository [1]. Instead I think it'd help if you could do it
> directly within a fork of the original repository [2].
> That way it'll be easier for other developers to follow progress
> and test changes as early as possible in the process.
> [1] https://github.com/vishaltiwari/GSoC-GEOS
> [2] https://github.com/libgeos/libgeos/
> --strk;
> On Fri, Jul 05, 2013 at 07:18:28PM +0530, vishal tiwari wrote:
> > Hi,
> > *1. Work Done:*
> >    - Came across with some more methods related to VoronoiDiagram in
> other
> >    class and also ported them.
> >    - Completed the port of VoronoiDiagramBuilder.
> > *2. Problems Faced :*
> >    - No problems faced as such.
> > *3. Work to be done in the next week:*
> >    - Write C++ testcases for QuadEdgeSubdivision class
> >    and VoronoiDiagramBuilder class.
> > Regards,
> > Vishal Tiwari
> > Undergraduate
> > Computer Science and Engineering
> > Lab for Spatial Informatics
> > IIIT-Hyderabad
> > geos-devel mailing list
> > geos-devel at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geos-devel
>  http://www.cartodb.com - Map, analyze and build applications with your
> data
>                                        ~~ http://strk.keybit.net
Vishal Tiwari
Undergraduate
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130709/9188bb2c/attachment.html>
