[geos-devel] [GEOS] #630: CMake with mingw fail
GEOS geos-trac at osgeo.org
Mon Jun 3 23:47:49 PDT 2013
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
 Mat,
 I'm getting similar error to ticket here #557
 I tried with both my existing 4.5.4 Mingw install and 4.8.0 that Mark
 suggested and get same failure.  On bright side 4.8.0 doesn't seem to
 crash like 4.6 did (when compiling with  ./configure), but gives lots of
 failures during regress testing like 46 out of 3000 failures. more on that
 later.
 My build command was:
 export OS_BUILD=64
 export GEOS_VER=3.4.0dev
 PROJECTS=/c/ming${OS_BUILD}/projects
 tools/svn_repo_revision.sh
 rm -rf build/mingw
 mkdir -p build/mingw
 cd build/mingw
 cmake -G"MSYS Makefiles"
 -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}
 make
 {{{-- The C compiler identification is GNU 4.8.0
 -- The CXX compiler identification is GNU 4.8.0
 -- Check for working C compiler: c:/ming64/mingw64/bin/gcc.exe
 -- Check for working C compiler: c:/ming64/mingw64/bin/gcc.exe -- works
 -- Detecting C compiler ABI info
 -- Detecting C compiler ABI info - done
 -- Check for working CXX compiler: c:/ming64/mingw64/bin/g++.exe
 -- Check for working CXX compiler: c:/ming64/mingw64/bin/g++.exe -- works
 -- Detecting CXX compiler ABI info
 -- Detecting CXX compiler ABI info - done
 -- Setting GEOS version 3.4.0dev as port of JTS 1.12.0
 -- Setting GEOS C API version 1.8.0
 -- Setting GEOS build type - Debug
 -- Forcing IEEE 754 using flag -ffloat-store - ON
 -- Setting GEOS compilation with small functions inlining - ON
 -- Setting GEOS compilation with assert() macro enabled - OFF
 -- Looking for include file stdint.h
 -- Looking for include file stdint.h - found
 -- Looking for include file inttypes.h
 -- Looking for include file inttypes.h - found
 -- Looking for include file ieeefp.h
 -- Looking for include file ieeefp.h - not found
 -- Looking for sys/types.h
 -- Looking for sys/types.h - found
 -- Looking for stddef.h
 -- Looking for stddef.h - found
 -- Check size of int64_t
 -- Check size of int64_t - done
 -- Performing Test HAVE_STD_ISNAN
 -- Performing Test HAVE_STD_ISNAN - Failed
 -- Looking for isnan
 -- Looking for isnan - found
 -- Performing Test HAVE_STD_ISFINITE
 -- Performing Test HAVE_STD_ISFINITE - Failed
 -- Looking for isfinite
 -- Looking for isfinite - found
 -- Enable GEOS Unit Tests build - ON
 -- Enable GEOS XML Tester build - ON
 -- Enable GEOS large geometry tests build - ON
 -- CMake 2.8.10.2 successfully configured geos using MSYS Makefiles
 generator
 -- Configuring done
 -- Generating done
 -- Build files have been written to:
 C:/ming64/projects/geos/branches/geos-3.4/b
 uild/mingw
 Scanning dependencies of target geos
 [  0%] Building CXX object src/CMakeFiles/geos.dir/algorithm/Angle.cpp.obj
 c:/ming64/projects/geos/branches/geos-3.4/src/algorithm/Angle.cpp:1:0:
 warning:
 -fPIC ignored for target (all code is position independent) [enabled by
 default]
 In file included from
 C:/ming64/projects/geos/branches/geos-3.4/include/geos/geo
 m/Coordinate.h:19:0,
                  from
 gle.cpp:23:
 C:/ming64/projects/geos/branches/geos-3.4/include/geos/geom/Coordinate.inl:
 In m
 ember function 'bool geos::geom::Coordinate::isNull() const':
 C:/ming64/projects/geos/branches/geos-3.4/build/mingw/include/geos/platform.h:13
 6:27: error: 'isnan' was not declared in this scope
  #  define ISNAN(x) isnan(x)
 C:/ming64/projects/geos/branches/geos-3.4/include/geos/geom/Coordinate.inl:38:10
 : note: in expansion of macro 'ISNAN'
   return (ISNAN(x) && ISNAN(y) && ISNAN(z));
 6:27: note: suggested alternative:
 gle.cpp:19:0:
 c:\ming64\mingw64\include\c++\4.8.0\cmath:836:5: note:   'std::isnan'
      isnan(_Tp __f)
                  from
 gle.cpp:23:
 In m
 ember function 'bool geos::geom::Coordinate::equals3D(const
 te&) const':
 C:/ming64/projects/geos/branches/geos-3.4/include/geos/geom/Coordinate.inl:77:21
    ((z == other.z)||(ISNAN(z) && ISNAN(other.z)));
 gle.cpp:19:0:
      isnan(_Tp __f)
 make[2]: *** [src/CMakeFiles/geos.dir/algorithm/Angle.cpp.obj] Error 1
 make[1]: *** [src/CMakeFiles/geos.dir/all] Error 2
 make: *** [all] Error 2
 warning:
 default]
                  from
 gle.cpp:23:
 In m
 gle.cpp:19:0:
      isnan(_Tp __f)
                  from
 gle.cpp:23:
 In m
 te&) const':
 gle.cpp:19:0:
      isnan(_Tp __f)
Ticket URL: <http://trac.osgeo.org/geos/ticket/630>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
