[geos-devel] Using the C API
Sandro Santilli strk at keybit.net
Fri Mar 15 11:11:43 PDT 2013
On Fri, Mar 15, 2013 at 05:10:24PM +0000, Richard Frith-Macdonald wrote:
> On 15 Mar 2013, at 10:32, Sandro Santilli wrote:
> > A patch to expose GEOSNearestPoints in the C-API will be welcome
> > for the 3.4.0 version. Please don't forget unit tests.
> OK ... here's a patch against the code in svn (assuming the mailing list allows it).
Thanks. Committed as r3792.
I had to move the test to the proper place, add to the Makefile.am,
and add a missing include to the geos_ts_c.cpp file.
No other change needed. Good work :)
Want to expose to the binding too since you're at it ?
--strk;
  http://strk.keybit.net
