[geos-devel] build/test report on NetBSD/sparc
Sandro Santilli strk at keybit.net
Mon Sep 23 07:34:10 PDT 2013
On Mon, Sep 23, 2013 at 10:28:21AM -0400, Greg Troxel wrote:
> Sandro Santilli <strk at keybit.net> writes:
> > Great. If you want to find the actual culprit you'll see
> > that testrunner is a shell script calling XMLTester with a long
> > argument list. Maybe you could reduce the list to find the offending
> > test and remove it ?
> It's so painful to build, but I'll see how it goes.   Modern software
> just doesn't fit in 24 MB of RAM :-(
> It would be nice if XMLTester got invoked once per test and there was
> clearer intermediate status.  But perhaps my case is degenerate.  (Are
> there test results from Raspberry Pi, Beaglebone, etc.?  Of course those
> have lots of RAM compared to retrocomputing.)
I don't know of any test results from those systems.
You can edit testrunner script and turn it into an iteration
on the list of tests invoking XMLTester on each.
Doing it by default could also be an option, why not...
But also catching OOM condition should do.
--strk;
