[geos-devel] [GEOS] #665: st_isvalid fails to detect invalid interior ring orientation
GEOS geos-trac at osgeo.org
Wed Sep 25 23:20:38 PDT 2013
 Reporter:  vmo         |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.3
Component:  Default     |     Version:  3.3.3
 Severity:  Unassigned  |    Keywords:
Comment(by aperi2007):
 in the 1.2.1 successively version of specs
 >OpenGIS® Implementation Standard for Geographic
 >information - Simple feature access - Part 2: SQL option
 >2010-08-04
 Seem it was corrected.
 Infact at page 105 they wrote:
 >Polygon rotation is not defined by this standard; actual polygon rotation
 may be in a
 >clockwise or counter-clockwise direction
 AFAIK this is for internal or external ring.
Ticket URL: <http://trac.osgeo.org/geos/ticket/665#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
