[geos-devel] [GEOS] #666: st_isvalid fails to detect 3 points polygons
GEOS geos-trac at osgeo.org
Thu Sep 26 01:24:46 PDT 2013
 Reporter:  vmo         |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.3
Component:  Default     |     Version:  3.3.3
 Severity:  Unassigned  |    Keywords:
 select st_isvalid(st_geomfromtext('polygon((0 0, 1 0, 1 1, 0 0))'));
 returns true, and should return false.
 This ring self-intersects (at all points).
 From Simple Feature Access - Part 1 (1.2.1), section 6.1.11:
 c) No two Rings in the boundary cross and the Rings in the boundary of a
 Polygon may intersect at a Point but
 only as a tangent, e.g.
 ∀ P ∈ Polygon, ∀ c1,c2∈P.Boundary(), c1≠c2,
 '''∀ p, q ∈Point, p, q ∈ c1, p ≠ q ,''' ''# the polygon in example does
 not satisfy this condition''
 [p ∈ c2] ⇒ [∃ δ > 0 ∋ [|p-q|<δ] ⇒ [q ∉ c2] ];
Ticket URL: <http://trac.osgeo.org/geos/ticket/666>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
