[geos-devel] [GEOS] #591: Port robust determinant fixes from JTS
GEOS geos-trac at osgeo.org
Fri Dec 5 01:42:22 PST 2014
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.5.0
Component:  Default     |     Version:  3.3.5
 Severity:  Unassigned  |    Keywords:
Comment(by mloskot):
 The two test cases with point-on-segment and point-on-vertext have been
 refactoried according to Martin Davis' suggestions (see
 https://github.com/libgeos/libgeos/pull/40) and added to the tests in
 r4038.
 This ticket remains open until complete or partial DD support is added
 (again, see https://github.com/libgeos/libgeos/pull/40)
Ticket URL: <http://trac.osgeo.org/geos/ticket/591#comment:12>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
