[geos-devel] [GEOS] #694: PreparedPoint::intersects gives different results from Point::intersects
GEOS geos-trac at osgeo.org
Fri Jun 20 01:40:07 PDT 2014
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.5.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 I've reverted the signature fix with r3989, but this issue should be fixed
 or it makes no sense to have an unused implementation for
 PreparedPoint::intersects.
 An automated testcase is needed in GEOS.
Ticket URL: <http://trac.osgeo.org/geos/ticket/694#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
