[geos-devel] MinGW build of Geos on Win7
Theuns Heydenrych theunsheydenrych at gmail.com
Tue Nov 4 01:02:04 PST 2014
HI All
When building Geos 3.4.2 with MinGW on Win7, the build fails at the last
step when trying to link the dll, with the following.
libtool: link: g++ -shared -nostdlib
c:/Tools/MinGW/bin/../lib/gcc/i686-w64-mingw32/4.9.1/../../../../i686-w64-mingw32/lib/../lib/dllcrt2.o
c:/Tools/MinGW/bin/../lib/gcc/i686-w64-mingw32/4.9.1/crtbegin.o
 .libs/inlines.o  -Wl,--whole-archive algorithm/.libs/libalgorithm.a
geom/.libs/libgeom.a geomgraph/.libs/libgeomgraph.a index/.libs/libindex.a
io/.libs/libio.a linearref/.libs/liblinearref.a noding/.libs/libnoding.a
operation/.libs/liboperation.a planargraph/.libs/libplanargraph.a
precision/.libs/libprecision.a simplify/.libs/libsimplify.a
triangulate/.libs/libtriangulate.a util/.libs/libutil.a
-Wl,--no-whole-archive
 -L/c/mingw491/i686-491-posix-dwarf-rt_v3-rev0/mingw32/opt/lib
-L/c/mingw491/prerequisites/i686-zlib-static/lib
-L/c/mingw491/prerequisites/i686-w64-mingw32-static/lib'
-Lc:/Tools/MinGW/bin/../lib/gcc/i686-w64-mingw32/4.9.1
-Lc:/Tools/MinGW/bin/../lib/gcc/i686-w64-mingw32/4.9.1/../../../../i686-w64-mingw32/lib/../lib
-Lc:/Tools/MinGW/bin/../lib/gcc/i686-w64-mingw32/4.9.1/../../../../lib
-Lc:/Tools/MinGW/bin/../lib/gcc/i686-w64-mingw32/4.9.1/../../.. -lstdc++
-lmingw32 -lgcc_s -lgcc -lmoldname -lmingwex -lmsvcrt -lpthread -ladvapi32
-lshell32 -luser32 -lkernel32 -liconv -lmingw32 -lgcc_s -lgcc -lmoldname
-lmingwex -lmsvcrt
c:/Tools/MinGW/bin/../lib/gcc/i686-w64-mingw32/4.9.1/crtend.o    -o
.libs/libgeos-3-4-2.dll -Wl,--enable-auto-image-base -Xlinker --out-implib
-Xlinker .libs/libgeos.dll.a
../libtool: eval: line 7867: unexpected EOF while looking for matching `''
../libtool: eval: line 7868: syntax error: unexpected end of file
make[3]: *** [libgeos.la] Error 1
make[3]: Leaving directory
`/c/cpp/dev/LibsExternal_/Gis/geos/geos-3.4.2/src'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/c/cpp/dev/LibsExternal_/Gis/geos/geos-3.4.2'
make: *** [all] Error 2
The problem is the ' after the
-L/c/mingw491/prerequisites/i686-w64-mingw32-static/lib' , library path.
I can go and fix it manually every time, but how can the makefile be fixed,
so that this ' is not appended to the end of this path?
Regards
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20141104/2a1cddce/attachment.html>
