[geos-devel] MinGW build of Geos on Win7
Theuns Heydenrych theunsheydenrych at gmail.com
Tue Nov 4 09:26:48 PST 2014
Thanks, I can give that a try.
One other thing I have noticed is that other projects that uses the same
tool chain, have no problems regarding this. (trailing ' character)
I checked the libtool version with libtool --version and geos libtool
version is 2.2.6 while the other is 2.4
The other projects is freexl, libiconv, libxml2 and gsl.
Maybe the libtool version for geos is too old?
But how to get a newer version into geos?
Send from Nexus 10
On 4 Nov 2014 18:16, "Sandro Santilli" <strk at keybit.net> wrote:
> On Tue, Nov 04, 2014 at 02:55:28PM +0200, Theuns Heydenrych wrote:
> > What i have figured out so far is to list the default search path for gcc
> > in MinGW is to issue the command
> > gcc -### -o foo foo.c
> > This will produce the following:
> > CPPFLAGS= LDFLAGS='-pipe
> > -L/c/mingw491/i686-491-posix-dwarf-rt_v3-rev0/mingw32/opt/lib
> > -L/c/mingw491/prerequisites/i686-zlib-static/lib
> > -L/c/mingw491/prerequisites/i686-w64-mingw32-static/lib'
> > So there right at the end is the "offending" path, some script that
> should
> > extract the -L paths, is bringing the ' character in, at the end of the
> > line.
> Good catch!
> > No where that script is and how to fix it i dont know.
> > Any suggestions?
> How about writing your own gcc wrapper to catch that call
> and print some context ?
> Or comment out portions of configure.ac until that call is not
> performed anymore and chase the offending macro, I would start with:
>   AC_PREREQ([2.52])
> --strk;
>   ()   Free GIS & Flash consultant/developer
>   /\   http://strk.keybit.net/services.html
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20141104/c9d622e6/attachment.html>
