[geos-devel] MinGW build of Geos on Win7
Theuns Heydenrych theunsheydenrych at gmail.com
Tue Nov 4 21:13:50 PST 2014
I am trying to build GEOS 3.4.2
On Tue, Nov 4, 2014 at 7:46 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Tue, Nov 04, 2014 at 07:26:48PM +0200, Theuns Heydenrych wrote:
> > Thanks, I can give that a try.
> > One other thing I have noticed is that other projects that uses the same
> > tool chain, have no problems regarding this. (trailing ' character)
> > I checked the libtool version with libtool --version and geos libtool
> > version is 2.2.6 while the other is 2.4
> > The other projects is freexl, libiconv, libxml2 and gsl.
> > Maybe the libtool version for geos is too old?
> > But how to get a newer version into geos?
> You should be able to copy the libtool script from the other projects,
> or (probably better) run the ./autogen.sh script if it comes with
> the source tarball.
> What version of GEOS are you trying to build, btw ?
> --strk;
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20141105/ae0b9671/attachment.html>
