[geos-devel] [GEOS] #591: Port robust determinant fixes from JTS
GEOS geos-trac at osgeo.org
Fri Nov 28 03:38:47 PST 2014
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.5.0
Component:  Default     |     Version:  3.3.5
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Not sure is related, but see also #694 for a case of "prepared"
 intersection involving points giving an unexpected result when fixed to
 really use the prepared code.
Ticket URL: <http://trac.osgeo.org/geos/ticket/591#comment:7>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
