[geos-devel] Buffering of invalid polygon seems to produce a less useable result
Sandro Santilli strk at keybit.net
Wed Oct 1 07:56:02 PDT 2014
On Mon, Sep 29, 2014 at 07:05:28PM +0000, Casper Børgesen (CABO) wrote:
> Are there any methods to better ensure validity of geometries resulting
> from the various geometric functions?
By contract, if the inputs are invalid, the output are not guaranteed
not only to be valid but also to be computable.
A valid input should always result in a valid output, or it would be a bug.
Turning an invalid geometry to a valid one can be tricky, you may want
to look at the ST_MakeValid funcition in PostGIS to see how it is
implemented.
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
