[geos-devel] Buffering of invalid polygon seems to produce a less useable result
Sandro Santilli strk at keybit.net
Thu Oct 2 00:59:37 PDT 2014
On Thu, Oct 02, 2014 at 06:16:58AM +0000, Casper Børgesen (CABO) wrote:
> Hi Sandro.
> Thank you for your answer. As far as I have checked, I'm starting out
> with valid geometries only. So if valid inputs guarantees valid output,
> I guess I have to go bug hunting.
Yep. Consider updating to latest geos development version,
either from 3.4 branch or trunk, at your choice.
Just in case the bug was already fixed...
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
