[geos-devel] Geos not compiling Ubuntu 12.0.4
Sandro Santilli strk at keybit.net
Fri Oct 10 09:38:52 PDT 2014
On Fri, Oct 10, 2014 at 06:01:30PM +0200, Rémi Cura wrote:
> Hey,
> After an update of geos (about 50 commits)
> ,I tried to compile geos with cmake :
> The build stop at 82 % with an error.
> Anybody had the same issue?
> Cheers,
> Rémi-C
> libgeos/capi/geos_c.cpp: In function ‘geos::geom::Geometry*
> GEOSClipByRect(const geos::geom::Geometry*, double, double, double,
> double)’:
> libgeos/capi/geos_c.cpp:491:64: error: ‘GEOSClipByRect_r’ was not declared
Just a guess: nobody added the new RectangleIntersection code into
the CMake build script. I know I didn't, and I'm pretty sure nobody
else did. The autotools build scripts are the officially maintained ones,
do you have problems using them ?
--strk;
