[geos-devel] Geos not compiling Ubuntu 12.0.4
Mateusz Łoskot mateusz at loskot.net
Sat Oct 11 08:44:28 PDT 2014
On 11 October 2014 16:05, Sandro Santilli <strk at keybit.net> wrote:
> On Fri, Oct 10, 2014 at 09:35:23PM +0200, Mateusz Łoskot wrote:
>> On 10 October 2014 18:38, Sandro Santilli <strk at keybit.net> wrote:
>> > On Fri, Oct 10, 2014 at 06:01:30PM +0200, Rémi Cura wrote:
>> >> Hey,
>> >> After an update of geos (about 50 commits)
>> >> ,I tried to compile geos with cmake :
>> >> The build stop at 82 % with an error.
>> >> Anybody had the same issue?
>> >> Cheers,
>> >> Rémi-C
>> >> libgeos/capi/geos_c.cpp: In function ‘geos::geom::Geometry*
>> >> GEOSClipByRect(const geos::geom::Geometry*, double, double, double,
>> >> double)’:
>> >> libgeos/capi/geos_c.cpp:491:64: error: ‘GEOSClipByRect_r’ was not declared
>> > Just a guess: nobody added the new RectangleIntersection code into
>> > the CMake build script. I know I didn't, and I'm pretty sure nobody
>> > else did. The autotools build scripts are the officially maintained ones,
>> > do you have problems using them ?
>> The CMake configuration does not maintain explicit list of files,
>> but it should collect all .cpp files [1] inside the src subtree.
>> [1] https://github.com/libgeos/libgeos/blob/svn-trunk/src/CMakeLists.txt#L14
> Uhm, then maybe geos_c.h was not regenerated ?
There is a command in the root CMakeLists.txt for it, so it should be generated
https://github.com/libgeos/libgeos/blob/svn-trunk/CMakeLists.txt#L305
Best regards,
Mateusz  Łoskot, http://mateusz.loskot.net
