[geos-devel] Toward 3.5.0 release (was: For PostGIS 2.2 moving forward make liblwgeom compatible between micro releases)
Sandro Santilli strk at keybit.net
Tue Aug 4 05:32:03 PDT 2015
On Tue, Aug 04, 2015 at 08:15:02AM -0400, Paragon Corporation wrote:
> Strk,
> As I recall and my memory may be wrong and I can't find the thread, but I
> said if I do it on windows it will get all mangled like when I did the GEOS
> 3.4.0 release. So I'd have to do it on Debbie.
> And you said, paraphrasing "Don't worry Regina, I'll take care of it, you
> just close all the tickets or push"
Alright, will do.
> > According to trac, the only thing left is a blocker build error on MinGW:
> > https://trac.osgeo.org/geos/ticket/736
> Other Sandro okay -- FWIW I don't build with the configure script since
> configure stopped working for me a while ago, I use CMake for building GEOS
> under MingW so I'm oblivious to this error.  If you can provide a patch that
> would be swell.
> If not I'll spend some time figuring out and then just push if I can't.
> > Me I'd also like to see the PHP exposure of ClipByRect:
> > https://trac.osgeo.org/geos/ticket/734
> > but if you handle to cut the release out before I handle to do that, it'll
> have to wait...
> Okay you might have to wait.
I actually just fixed this PHP one :)
> > Did anyone respond to the call-for-testing on geos lists ?
> What call?  People, especially package maintainers don't like testing stuff
> unless it's in an unchanging tar ball.
Uhm, I though you sent a call for testing, evidently you didn't.
Would tagging an RC1 give packagers an unchanging tarball ?
--strk;
