[geos-devel] [GEOS] #743: Number of buffered points not always a multiple of quadSegs
GEOS geos-trac at osgeo.org
Mon Aug 17 17:47:51 PDT 2015
 Reporter:  mwtoews    |       Owner:  geos-devel@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  3.5.1
Component:  Default    |     Version:  3.5.0
 Severity:  Annoyance  |  Resolution:
 Keywords:             |
Comment (by robe):
 Does the issue exist on all versions of GEOS you tested with?  Which
 version e.g. GEOS 3.4.2 did you test?
Ticket URL: <https://trac.osgeo.org/geos/ticket/743#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
