[geos-devel] [GEOS] #753: cannot build geos 3.5.0
GEOS geos-trac at osgeo.org
Wed Nov 4 06:41:01 PST 2015
 Reporter:  rashadkm    |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.5.1
Component:  Default     |     Version:  3.5.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by rashadkm):
 sucessfully built geos 3.5.0 for osgeo4W 32bit
 1. geos-3.5.0.tar.gz from
 http://download.osgeo.org/geos/geos-3.5.0.tar.bz2
 2.
 https://trac.osgeo.org/geos/browser/trunk/CMakeLists.txt?rev=4112&format=txt
 3.
 https://trac.osgeo.org/geos/browser/trunk/cmake/modules/GenerateSourceGroups.cmake?format=txt
 and  when running cmake, I added -DCMAKE_CXX_FLAGS:STRING="-DNOMINMAX"
 TODO:
 backport (2) and (3) to 3.5.0 release
 include -DNOMINMAX patch inside the (1) if compiler is MSVC.
 optional. I would also added /EHsc for msvc compiler in the cmakelists.txt
 Do you prefer to create a patch against trunk?
Ticket URL: <https://trac.osgeo.org/geos/ticket/753#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
