[geos-devel] Exposing PrecisionModel, GeometryPrecisionReducer in the C API
Sandro Mani manisandro at gmail.com
Thu Oct 1 09:14:10 PDT 2015
On 01.10.2015 18:08, Sandro Santilli wrote:
> On Thu, Oct 01, 2015 at 06:02:20PM +0200, Sandro Santilli wrote:
>> Sandro, others:
>> here's what I'm thinking to add as the single new signature
>> to the C-API for GEOS-3.6.0, what do you think ?
>>    * Set the geometry's precision, optionally rounding all its
>>    * coordinates to the precision grid (if it changes).
>>    * @param gridSize size of the precision grid, or -1 for FLOATING
>>    *                 precision.
>>    * @param forceSnap specifies whether snapping to the precision grid
>>    *                  should be forced: -1 prevents snapping, which can
>>    *                  be used when the input is known to be already
>>    *                  rounded to the target grid; 0 only snaps if the
>>    *                  new precision grid is not equal or compatible with
>>    *                  the new precision grid; 1 always snaps.
>>   extern GEOSGeometry GEOS_DLL *GEOSGeom_setPrecision_r(
>>                                         GEOSContextHandle_t handle,
>>                                         double gridSize, int forceSnap);
>> Of course it can only work if the memory management for
>> GeometryFactory is automatic, as proposed in the PR
>> (which might be dangerous for any existing C++ client out there).
> Of course there must be a GEOSGeometry argument too:
>   GEOSGeometry *GEOSGeom_setPrecision_r(
>                                         const GEOSGeometry *g,
> I'm not sure about returning a copy. One idea was, in the long run,
> to also make GEOSGeometry objects automatically managed as per memory
> lifetime, such thing would be easier by threating geometries as
> immutable objects (and this is also the policy used in JTS); but
> there's a known single function that is already not respecting that
> immutability, which is GEOSNormalize.
As far as QGIS is concerned, it might also be an idea to just have a
function which sets the precision geos-context-wide:
void GEOS_setPrecision_r(GEOSContextHandle_t handle, double gridSize)
removing the need to do all the cloning of geometries just to reduce the
precision. After all, all QGIS geometry processing functions would
benefit from reduced precision computations.
