[geos-devel] Exposing PrecisionModel, GeometryPrecisionReducer in the C API
Sandro Mani manisandro at gmail.com
Thu Oct 1 10:01:33 PDT 2015
On 01.10.2015 18:58, Sandro Santilli wrote:
> On Thu, Oct 01, 2015 at 06:51:44PM +0200, Sandro Mani wrote:
>> On 01.10.2015 18:47, Sandro Santilli wrote:
>>> Cleaned up proposal. No copying, using 0 for FLOATING and returning
>>> previous precision.
>>>     * Set the geometry's precision, optionally rounding all its
>>>     * coordinates to the precision grid (if it changes).
>>>     * @param gridSize size of the precision grid, or 0 for FLOATING
>>>     *                 precision.
>>>     * @param forceSnap specifies whether snapping to the precision grid
>>>     *                  should be forced: -1 prevents snapping, which can
>>>     *                  be used when the input is known to be already
>>>     *                  rounded to the target grid; 0 only snaps if the
>>>     *                  new precision grid is not equal or compatible with
>>>     *                  the new precision grid; 1 always snaps.
>>>     * @retuns -1 on exception, previous size of precision grid otherwise.
>>>    extern int GEOS_DLL *GEOSGeom_setPrecision_r(
>>>                                           GEOSContextHandle_t handle,
>>>                                           GEOSGeometry *g,
>>>                                           double gridSize, int forceSnap);
>>> I guess one might want a _getPrecision too...
>> I like the in-place approach. So as far as my needs go, this would
>> be perfectly adequate. (And about the generic GEOS_setPrecision,
>> looks like too much trouble).
> Great, I'll be pushing an implementation of that to the same PR
> with the automatic memory management for GeometryFactory (which
> seems an indispensable part of this) tomorrow, stay tuned for
> tests your side !
Cool, thanks!
