[geos-devel] [GEOS] #746: GitLab default branch
GEOS geos-trac at osgeo.org
Mon Sep 21 00:37:53 PDT 2015
 Reporter:  mwtoews     |       Owner:  geos-devel@…
     Type:  task        |      Status:  closed
 Priority:  minor       |   Milestone:  3.5.1
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
 * milestone:   => 3.5.1
Comment:
 Default gitlab branch set to trunk, thanks for looking at that new mirror.
 If you want to play with the gitlab CI I'll be happy to add you as a
 gitlab/geos contributor (or what it takes)
Ticket URL: <https://trac.osgeo.org/geos/ticket/746#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
