[geos-devel] php-geos 1.0.0rc1 ready for test
Sandro Santilli strk at kbt.io
Tue Aug 30 02:12:17 PDT 2016
On Tue, Aug 30, 2016 at 10:41:06AM +0200, Sebastiaan Couwenberg wrote:
> On 08/30/16 10:09, Sandro Santilli wrote:
> >Version 1.0.0rc1 of php-geos is available for download and test
> >from https://git.osgeo.org/gogs/geos/php-geos/releases
> >This is the first standalone php binding for GEOS, it should
> >work against any GEOS version since 3.1.0 (for thread-safe API).
> >If no bug is reported within a week, the tag will be converted
> >to final 1.0.0.
> Will the php bindings for GEOS remain a separate project, and no
> longer be bundled with future GEOS releases?
Yes, this is the plan. GEOS-3.6.0 will be the first release
with no embedded PHP bindings.
> And most importantly, does php-geos 1.0.0rc1 support PHP 7?
Yes!
A buildbot is checking it for working against both PHP5 and PHP7,
example: https://drone.osgeo.kbt.io/geos/php-geos/33
The build is based on an ad-hoc docker built via
docker/build-test/Dockerfile.trisquel
--strk;
