[geos-devel] [GEOS] #757: IsValid memory exhaustion with degenerate multipolygon
GEOS geos-trac at osgeo.org
Wed Jan 20 00:37:29 PST 2016
 Reporter:  pramsey     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.5.1
Component:  Default     |     Version:  3.5.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by strk):
 Paul: you should find in the header of each .cpp and .h file a reference
 to the last JTS revision being ported.
 Could you please also update that value (or add if missing in those
 specific files) so we know where we are, on next port drive ?
 TIA
Ticket URL: <https://trac.osgeo.org/geos/ticket/757#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
