[geos-devel] [GEOS] #784: g++ 6 isnan issues
GEOS geos-trac at osgeo.org
Thu Jul 14 04:06:52 PDT 2016
 Reporter:  rsbivand    |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  blocker     |   Milestone:  3.5.1
Component:  Default     |     Version:  3.5.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by strk):
 In [changeset:"4225" 4225]:
 #!CommitTicketReference repository="" revision="4225"
 Look for isnan in std:: namespace
 Fully qualify isnan call when HAVE_ISNAN is defined
 Tested with gcc 4.8.4
 Fixes build with GCC-5.3.0 and higher.
 Closes #784
Ticket URL: </ticket/784#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
