[geos-devel] GeometryFilter vs GeometryComponentFilter on GeometryCollection
Sandro Santilli strk at keybit.net
Fri Mar 4 06:44:49 PST 2016
On Fri, Mar 04, 2016 at 02:02:22PM +0100, Mateusz Loskot wrote:
> Is this intentional that both filters pass the root geometry
> (containing GeometryCollection or Multi*)
> itself to apply_rw and apply_ro?
I'd think the component filter should pass components, rather
than the root, but might be missing something. Did you check if
the class is used at all in the current codebase ? Are there
unit tests in JTS covering those classes ?
--strk;
