[geos-devel] Extraction of PHP extension into PECL-style package
Sandro Santilli strk at keybit.net
Thu Mar 10 14:02:30 PST 2016
On Thu, Mar 10, 2016 at 11:00:27PM +0100, Sandro Santilli wrote:
> On Thu, Mar 10, 2016 at 10:35:09AM -0500, J Smith wrote:
> > On Tue, Mar 8, 2016 at 12:48 PM, Sandro Santilli <strk at keybit.net> wrote:
> > > http://strk.keybit.net/tmp/check_out2.txt
> > According to that second output you have, all tests passed? The output
> > look similar in both, but if you'll notice in check_out2.txt, they're
> > actually all succeeding now. The PHP unit test output is a bit stiff
> > and not really readily eye-ball-able if you will. :/
> Indeed. I think a good test is as succint as possible (report number
> of run/passed/failed tests and eventually time it took) unless
> something goes wrong, in which case it should give the least
> information useful to re-produce the failure.
> Is there any possibility to improve the output with that in mind ?
Also, the "make check" run ends with prompting me, which is really
annoying. The prompt asks if I want to send the report to the PHP QA
team. Really ? Should we send successful test run reports for a single
package to "the PHP QA team" ?? I wouldn't want to be in that team :)
--strk;
