[geos-devel] [GEOS] #795: Port IndexedFacetDistance from JTS
GEOS geos-trac at osgeo.org
Mon Oct 31 15:27:52 PDT 2016
 Reporter:  dbaston      |       Owner:  geos-devel@…
     Type:  enhancement  |      Status:  closed
 Priority:  major        |   Milestone:  3.7.0
Component:  Default      |     Version:  svn-trunk
 Severity:  Unassigned   |  Resolution:  fixed
 Keywords:               |
Comment (by strk):
 In [changeset:"4300" 4300]:
 #!CommitTicketReference repository="" revision="4300"
 Fix memory leak in IndexedFacetDistance
 Patch by Dan Baston (see #795)
Ticket URL: <https://trac.osgeo.org/geos/ticket/795#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
