[geos-devel] Building a small/core version of geos
Kurt Schwehr schwehr at gmail.com
Thu Apr 20 09:52:07 PDT 2017
Hi all,
First off, I'm doing this with bazel as the build system, so I'm not
worried about making sure I don't break the CMake or autoconf builds.
I'm looking to see if I can build a subset of geos with the goal of being
able to just use the io WKT portion of geos with the least amount of the
rest of geos brought in with the core lib.  I then will add the rest of the
geos lib that depends on the core.  Anyone tried that before or have
thoughts on how hard it would be to do that?  e.g. some code would only
need the geometry representation of WKT source and it would be best to pull
in the least amount of other code with it.  That would also make testing of
things like io as light as possible.
I'm going to see what I can remove while still being able to run my tests
that are here:
https://github.com/schwehr/gdal-autotest2/tree/master/cpp/third_party/geos
/io
Thoughts?
-kurt
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20170420/69f8707e/attachment.html>
