[geos-devel] [GEOS] #638: Recommend a static_cast around assert strings
GEOS geos-trac at osgeo.org
Tue Jan 31 12:04:04 PST 2017
 Reporter:  goatbar     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.7.0
Component:  Default     |     Version:  3.3.8
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by strk):
 You don't necessarely need the github machinery, just a publicly
 accessible
 branch in a git repo you can write to :)
 That said, if you want to use a web UI mediated branch tracking issue
 feel free to use it on any of the available mirrors: github, gitlab or
 gogs
 (the latter lets you use the same account you're using to write here).
 See wiki:CodeRepository (blindly trying the TracLink)
Ticket URL: <https://trac.osgeo.org/geos/ticket/638#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
